1 - 10 of 10 Posts
I have seen recommendations here on this forum about using ER70S-7 mig welding wire on sheet metal repairs because it is soft enough to grind.
My question is: Where do you get it? I have tried to find it on line and at three different welding supply stores locally and none of them have it. I have ER70S-6 on my welder now and that is all they have in stock. Is this wire a lot harder than the -7?
Wayne
Is that the stuff that's marketed as EZ Grind or something similar? You can probably buy it on the internet, try Google or Amazon.
I wouldn't expect miracles with the EZ Grind stuff. I tried it once and couldn't tell the difference.
ER70S-6 is the most common recommendation and also the easiest to find. It works fine for most.
RickL, I am not sure what it is, I just read a couple of different threads a while back that recommended the ER70S-7. so I tried to find some with no luck. I found a site on the internet that listed it but only sold to commercial applications in very large quantities.
I will just continue to use what I have, it does not hammer very well and is pretty hard, but I will make do.
Wayne
Mig welds are too big and too hard to hammer, no matter what wire you use.
If you want to planish your welds (and it's the right thing to do), do it after you dress the weld flush or nearly so. Otherwise you're wasting your time.
A good gas weld or a good tig weld might be able to be planished without dressing the weld. But that would be only if your welding required almost no grinding.
Good luck, hope this helps.
but the -7 was an improvement over the -6 in the areas I mentioned above.
That's some good info, thanx for posting it. This still leaves the prob of where to find? I've had trouble locating it myself, and want to try it.
Quite a while back a member mentioned that wire in a thread somewhere which got my interest. I wish I could remember who. It might have been Bam55 maybe.
Dan
I wish I knew how to gas weld or tig weld, but I don't know how to do either and I think trying to learn on the floor of my 57 is not a great idea.
I still have not found a source for the -7 wire.
Wayne
Wayne
I found it on eBay.
Don
I am having trouble locating ER70S-7 .023 MIG Wire to fit my Lincoln 180 MIG which can handle a max spool size of 8" and 10 lbs
Does anyone know where I can obtain it?
LS Tech and Moderator
TIG on something like a floor pan would take forever no real advantage IMO.
With the correct settings and gaps ER70S-6 works fine. Don't try to fill all in one shot mean stacking welds on welds. I usually stitch an area let cool and will clean it up then stitch more. Biggest mistake I see is grinding to much and getting it too hot. Grinder makes alot of heat quick and it will wrap too.
1 - 10 of 10 Posts
