1 - 11 of 11 Posts
I took the ram horn style exhaust manifols off my small block 350 to strip and paint them with the POR-15 high heat paint.The passenger side was a piece of cake,but the driver side was a PAIN.I had to remove the alternator,spark plugs,valve cover,and take the bolts out of my steering gear box!Needless to say I only want to do this once!!!!Which gaskets have you guys had better luck with copper or aluminum?Which are thinner,because I dont have alot of clearance between the manifold and ps gear box.Just wanting to get some input from guys who have been there done that!Thanks!
gaskets
When using stock manifolds, I've always had good luck not using gaskets. I make sure manifolds are flat using a belt sander and use nothing between manifold and heads. Headers are a different story.
72 Vette
I read your post couple of days ago. I really dreaded trying this. Well, on a 72 Vette its as easy as pie. Took them loose from the bottom first, then top. Blasted them, used the high temp POR. After drying they went back on as easy as off. I used standard silver sided gaskets. :wavey:
I use ultra copper permatex and machine my manifolds flat. I never have leaks with this method
I've always had good luck making sure both mating surfaces were good and clean and machined flat. Then installed manifolds without gaskets. :anim_25: That's when I used manifolds. Now I am running Sanderson headers. :happy0030:
I've never used gaskets with stock V8 manifolds. Just make sure the mating surfaces are flat and true.
No leakage problems.
Chuck
I know people that do that, but I've always been afraid of leaks.
Chevrolet built MILLIONS of V8's without gaskets, and had no problems. :D
Plus, I think they look cheesy.
Chuck
If it is an old manifold that has had gaskets on it before you might try taking a wet rock and just plane it over the gasket surface until it cleans it up.
1 - 11 of 11 Posts
