Hello All:
I have a question regarding the installation of Eckler's ABS fan shroud for a V8radiator in the six cylinder position.
My radiator has been moved to the six cylinder position with adapter plates.
The rad support is a V8 rad support. At first glance it does not appears that this shroud is going to fit if I have to have the shroud right up against the radiator. It appears that the opening from the bottom of the upper brace to the bottom of the radiator support is smaller than the outside dimensions of the fan shroud. Has anyone installed this shroud in this configuration. Do not want to start cutting and hacking the shroud or the radiator support.
Thanks:confused0006::confused0006:
