1 - 3 of 3 Posts
I had a 9" rear end narrowed a couple of years ago and finally got it into the car, problem is there was a misunderstanding about left and right dimensions and pinion center. It's about 2" to one side. Can I run this in the car or will I have driveshaft-u-joint alignment issues? Do I need a new rear end? Any suggestions? thanks
The offset probably isn't as big a problem for driveshaft vibration as it might be for clearance to the tunnel in the floorpan. You can check that out yourself.
1 - 3 of 3 Posts
