A spring is a spring and a shock is a shock. It doesn't matter whether you have coilovers or stock stuff if the spring rates and shock rates are the same between the two and correctly chosen. The advantage of a coilover is adjustability and weitght.
A spring is a spring and a shock is a shock. It doesn't matter whether you have coilovers or stock stuff if the spring rates and shock rates are the same between the two and correctly chosen. The advantage of a coilover is adjustability and weitght.I don't know how a coilover setup would help unless I was making right and left turns quickly? Would it?
And by the way, I did message the above seller and he had no clue what so ever what "performance" in his ad meant. He said all he knows is what's on the box when he receives them and there were no specs on the box or inside with them.It's wording like this that really gets people confused about control arms. Just what does "performance" mean? It doesn't mention anything about extra caster. For all you know, they may be the same as the old stock ones. Just for the heck of it, I asked the seller ""exactly what does "performance" mean?""
Performance Upper & Lower Tubular Control Arms A-Arms For Chevy Belair 210 150 | eBay
Find many great new & used options and get the best deals for Performance Upper & Lower Tubular Control Arms A-Arms For Chevy Belair 210 150 at the best online prices at eBay! Free shipping for many products!www.ebay.com
Yeah. I bought some Tubular arms from A-Team for my 57 Chevy that were supposed to bolt right in. WRONG. And they will not refund my money. I'm now looking at replacing my control arms with factory arms.IMHO the stamped arms with the additional caster (they come with cross shafts, ready for installation), taller ball joints, and a sway bar is about the 'best value' arrangement.
Chevy Upper Control Arms, Positive Caster, Original Style, 1955-1957
Finally! The wait for a stock look upper control arm with positive caster built in is over! Eckler's Classic Chevy brings you a heavy, stamped steel upper A-arm with the ball joint moved to net you 5 degrees of positive caster in your 1955, 1956 or 1957 Chevrolet Bel Air, 150, 210, Nomad or...www.classicchevy.com
There are plenty of other areas to spend $ on![]()
Be sure to get the uppers with the +5 camber built into them.Yeah. I bought some Tubular arms from A-Team for my 57 Chevy that were supposed to bolt right in. WRONG. And they will not refund my money. I'm now looking at replacing my control arms with factory arms.
I got mine from CPP.Do you have a source?
CPP makes & sells them but if you want a reasonable delivery time order them from Summit Racing. You will get free shipping & a faster ship time.Do you have a source?
Thanks. I've ordered other things from Summit as well as Classic Industries. So far, so good.CPP makes & sells them but if you want a reasonable delivery time order them from Summit Racing. You will get free shipping & a faster ship time.
1955 CHEVROLET BEL AIR Classic Performance 5557SCA-U5 Classic Performance Stock-Type Control Arms | Summit Racing
DJ's 57, I finally installed the CPP tubular a-arms with the better ball joints more than a year ago, no problems with the front end alignment or with the sway bar. I like the way it handles now and I am able to turn and make u-turns with ease.Thanks. I've ordered other things from Summit as well as Classic Industries. So far, so good.
After the fiasco with A-Team tubular a-arms, I'm leery of all of them as they all appear the same. So, I think I'm going to stick with original a-arms with the +5 degree camber built in as recommended by 55Tony. Just installed Borgeson power steering. Know anyone who wants some used tubulars? Will need to replace a couple of boots. I'll make a good deal on them.DJ's 57, I finally installed the CPP tubular a-arms with the better ball joints more than a year ago, no problems with the front end alignment or with the sway bar. I like the way it handles now and I am able to turn and make u-turns with ease.
Considering what you have gone through with A-team tubular a-arms, I would do the same. Good luck.After the fiasco with A-Team tubular a-arms, I'm leery of all of them as they all appear the same. So, I think I'm going to stick with original a-arms with the +5 degree camber built in as recommended by 55Tony. Just installed Borgeson power steering. Know anyone who wants some used tubulars? Will need to replace a couple of boots. I'll make a good deal on them.
Thanks!
