My floorboards have two access holes in the front of each front floorboard. One has an indentation that looks like it was made so a plug/grommet would sit flush, the other does not. Wanted to make sure that both holes get grommets. Would be grateful if someone could confirm that.
Stainless Trim Restoration
The one with an indent is the convertible only extra body mount. On all other cars it got a water proof carboard cover that was glued in. There are rubber grommets, not made for this hole, that you can use. The other takes a grommet, but it is only made by T&N as all the others sold are too large for this hole, and you CANNOT force it into the hole.......
Mikey
55wagoncrazy
