Hi all. Does anyone have the measurement for the front seat braces that go under the floor? I have a seat That I could measure but it is 300 miles away in storage. Not a good place for it to be when I’m trying to finish up the floor on my 55 2 door sedan. Thanks
Do you mean these? Deminsions are in the description. Are you building some or need the hole spacing? https://www.danchuk.com/ItemForm.aspx?Item=1377
Discussion Starter #4
Sorry I have those braces I’m needing the location measurements. Maybe the width of the seat mounting holes from left to right so I can place the braces in the correct location.
The inside edge of all 4 inside bolt holes, is 8 7/8" from the inside edge of the pinch weld. Center to center between the rear bolt holes is 45 1/4".
P.S. Welcome. Are you a member of the Dallas tri-5 club? http://www.dallasclassicchevy.com/
Tell us about your project in the "Welcome section".
Discussion Starter #7
Thank you! You’re a life saver. I’m not a member. I will check it out & join. This car I originally bought when I was 13 years old. I will tell the story later. Thanks again
