1 - 2 of 2 Posts
installed a 350 in my 56 kept the original front engine mounts. Now having a problem installing a fuel line from the pump to the carb. The outlet on the replacement pump exits in a way exits the fuel line into the front motor mount. Anyone have a better pump to recommend or a place where I can get a 90* fitting that will screw into the pump and allow me to install a fuel line going straight up towards the intake?
Don
There are several pumps available that have a multi-position bottom bowl....they have about 8 0r 10 bolts and can be rotated 360 degrees to head your fuel line in the direction you need.Edelbrock,as well as many other companies,makes one.....that's what I use on all of the rods I build to avoid your problem.They are available thru Summit,Jegs,Speedway and several other suppliers.
1 - 2 of 2 Posts
