Can you miss the push rod, mount the fuel pump flush, crank the engine, and not bend or break the push rod or the pump lever? I learned the lesson as a teenager that you have to hold back the push rod and get the lever under the tip.
Can you have a fuel line air leak without some gasoline moisture seeping out? I understand you can lose suction with even a minor air leak.
283 bored 0.60 over, original Carter 4-barrel WCFB, 4 to 5.5 psi fuel pressure.
Precision Fuel Pump - M23031 installed in Nov. '22 - I was never satisfied that it was delivering fuel and I finally put a pressure gauge in the fuel line. At idle 3 psi, rev it up fluctuated dropping to 0.5 psi. Likely the reason it spit and sputtered around 40 mph and drove easy under 30 mph.
Installed a new M23031 today. Blew out fuel line back to tank and up to carb. Insured gravity flow brought fuel to pump, and it filled the pump bowl. Cranked engine several times for 5 to 10 seconds, primed carburetor, and could not get fuel up to carb. Took it off, reinstalled, tried some more and even removed output side to see if any fuel would spit out of pump. Zip, nothing.
Waiting for delivery of pump #3 and yes, I would love to find a more reliable part.
If I can find good instructions/tips for electric pump system, I will consider the swap out.
Thanks.
Thanks.
