I just bought a new fuse panel and it has a small wiring harness that came with it.. It has three wires Red, Pink and grey. We are using a stock new under dash harness. My question is do I use these 3 new wires as the old fuse panel did not have these? Thanks Deb
I'm sure Don can answer in more detail but the red is used for constant power and the pink is for accessory power. I belivev the grey is used for the headlight/dash circuit. Were there any wiring instructions that can with the new fuse panel?
Is the fuse panel you bought like the old panel or is it an modern style panel? If it's like the original, I don't think you use the small harness, the wires are in the under dash harness.
Where did you get the fuse panel at? Do you have a part number?
