· Registered
Any v8 68-72 Chevy pickup should have what you need, as long as you have a short water pump and tapped head ends. If not, you can adapt the header brackets to fit. You'll probably need a slightly longer belt though. Jeg's, Summit, Speedway all have the brackets.
Short water pump, no bolt holes in heads....Do not want to grind one side....Putting alt on driver's side....Should be able to make a bracket like Henry suggested....Thought maybe somone had done it before.
