I have a rebuilt?? generator, is there a way to check the generator to see if it is working? What should the voltage reading be when it is turning but not connected to the regulator. I can't tell if the regulator is not working or the generator is not working ?? Thanks Jerry
Discussion Starter #2
generator check
OK I figured out how to check the generatorand it is OK now how do you check the voltage regulator??? Thanks Jerry
Jerry...This is a voltage regulator test guide that Jalapeno has posted before.....Hopefully, it is large enough for you to see.
