I got the 55 back yesterday from media, and he also sealed the body(baked on). Now im going to start cutting out my floor for a full floor pan replacement, but i have some questions. I understand that i should cut the floor out close to the spot welds, remove the floor, and drill/grind the spot welds as they will be easier to get to after the floor is out of the way. My question is, once i cut the floor , do i lift the body off and remove the spot welds with the body off? If so, what do you set the body on, blocks, jackstands? And can i do this with 4 guys. Finally do i need to brace the body, its a sedan with soild rockers, i was thinking that one brace from side to side would be okay.
I don't know the answer to your question but from the pic's the floor doesn't look that bad. I know it's hard from the pictures but if you don't need to replace the whole floor I wouldn't. They do sell the individual panels for the floors. That's what I ended up doing as my rear pass floor was rotted. Godd luck as it looks to be in real good shape,
Before you start cutting the floor I would weld in some bracing ,,,IMO:) that floor does look pretty good , I agree, maybe patch panels would work and be a lot easier ,,
I agree. If the floor just has a few pin holes here and there, patch panels are just as good. Sure would save you a lot of money and effort. Good luck.
There are a lot of pin holes everywhere and deep craters from the rust also. I would have a lot of patch panels unless i got half floors (full length) for both sides.
Just looks like you may need floor pans, the centre tunnel looks beaten up depending wether your going with a floor shift you could work with something.
If you do decide to go with a full floor replacement get one with floor braces, look at your inner & outer rockers, towards the rear theres a two piece section for the tail pan that usually rusts out.
Brace so the body does not flex, preventing issues with door alignment.
I'd like to share an experience I just had my floors were very similar. They were rusted on both sides, paper thin ,so I opted to replace three rear pans and some braces. Bottom line, almost $3000 spent for pans braces and labor and it looks like patch job. I wish that I had braced it up and put a full pan in with braces. I know its a difficult decision.
I went with the advice of my bodyman and
got him to replace the full floorpan with braces,
and I'm glad I did.
I guess I drilled out 140 spotwelds to remove the
old braces for nothing.:sign0020:
I know that if it's feasible to keep as much of
the original floorpans as possible.In my case it
wasn't.
Here's a before and after photo of the floorpans.
The body braces are already removed in the before photo.
Sometimes you just need to bite the bullet. Driving in New England winters then sitting in a barn for 20+ years with dirt floors does a toll in the floor and frame. It is getting done ... slowly
