1 - 20 of 21 Posts
Wayne, Wow that looks so nice sitting in the frame. I'm am thinking that it will run as good as it looks. / I see yours and wish I was finishing mine instead of being forced to sell it. (A 68 Camaro project only) Because of thieves that caused me to lose over $600,000.00 I am going to sell the project. FYI, asking $8500.00 FOB Tulare, CA 93274
Larry From Tulare
Monarc[email protected]
Looks great brother..
what was up with the motor?
Rick
Still same as when i took it off the Dyno have not run it again it is showing 2 fault codes 51 and 81 , wont let it rev over 4000 rpm it is running and idling so i thought just get it in and put it together ,
sort it out later it is some electrical issue most likley.
Wayne ,
Miss ya Bud !!
The last time I put a 502 ramjet in a car it had issues .It turned out that the GM wiring diagram had a mistake in it! That was about 4 yrs ago.Thought that they would have corrected the instructions by now!
:gba:
Wayne ,
Miss ya Bud !!
One thing to read in the fine print on new computer controlled motors. They are set to default to no more than 4000rpm (green code) until a certain number of hours or miles on the motor, then it will wake up and fly.
Check your to see what it says.
nice, thanks for sharing. :tu
Wayne ,
Miss ya Bud !!
Miss ya to brother.....
I bet once you get the motor 100% installed in the 57, and all the grounds hooked up, that 502 is going to RUN LIKED A RAPED APE :p3:
your brother from another mother :)
Rick
Install
Now thats what I call a motor. Great looking ! Mike
1 - 20 of 21 Posts
