Hey guys,
I would like a header recomendation for my '56. Set-up is:
Small block
Stock front mounts and stock bellhousing mounts
Manual Z-bar
Stock manual steering box
I am looking for 1 3/4" full length, quality header. I have full lenghts on the car now, but the steering linkage hits the header tubes in both directions, and I am not getting full steering. I tried dimpling the header, but it is not enough.
Any advice is appreciated.
Randy
They are fine if you don't have a lowered car and need ground clearance.
Actually they are somewhat at risk at stock height. Depends on the driveways and speed bumps you encounter.
Thanks Rick,
I do have full lenghts on the car now that hang down under the frame horns, never had an issue. The car is stock height though, I imagine if it was lowered it would be a huge problem!
