Heater & AC Hose Dress Up
698 Views 2 Replies 2 Participants Last post by  husker71
Hi Guys!
I want to dress up these hoses with steel braid or chrome covering. Heater hoses are 3/4" and the AC hoses are 1". I can't disconnect the hoses to slide a covering over them and need a suggestion on what to use...
Thanks from Belleair Beach, FL!
1 - 3 of 3 Posts
I think that you're out of luck on this one. I can't think of anything with a steel braid look that can be applied without disconnecting the hoses. I used some steel braided sleeves from Spectre many years ago, then finally just went ahead and installed the real thing. It's a little spendy, but if that's the look you want, well worth the cost.
Best of luck.
Ray
Thanks, Ray!
I'm looking at ConvoShield™ AL Aluminized Slit Tubing to see if it will work and if it does I'll post the results...
Thanks Again...
1 - 3 of 3 Posts
