Hello All,
I have finally decided to change out my old points style distributor for an HEI unit. My question is: Do I just take the brown and green wires off the Ballast resistor and connect to the distributor? Or do I need to trace these 2 wires back to key switch and run new wires?
I get nervous pulling and removing wires, especially since the ignition system seems to be stock. Don’t want to screw anything up. Thanks!
Automotive lighting Flash photography Electrical wiring Motor vehicle Automotive tire
You need to run a larger wire from ign1 and 1gn2, on the switch, to the HEI. The original 20 gauge is just not big enough for an HEI. At least 14 gauge.
