21 - 24 of 24 Posts
So Plaer........U left us hangin’. What header did you find to fit yur application?
I’m going same direction as yur build
Discussion Starter #24
Pic 1&3 shows clearance after tweaking, pic 2 is the dent i had to make on tube 3, pic 4 is the hedmann number. The drivers side DIDNT fit, i had to take an angle grinder with a large disc and skim along the tube side of the flange. I cut from the underside 99% of the way through leaving a thin connection at the top of every tube then flexed the flange in taking up the space made by the thicker cutting disc. I did it twice but once would have been just enough. Welded it and drank some beer!! Reply if you have questions.
21 - 24 of 24 Posts
