1 - 2 of 2 Posts
on a 2inch lower leaf spring witch way does the resverse eye go? to the front of car or back of car? right now i installed the leaf springs with the resverse eye to the front of car . and i have been told that was wrong. thanks for the help
your spring should come with a bushing already installed. this goes to the front. if no bushing - t seems both eyelets are different on each end. the rear bushings should only fit the one end. also, most reversed eye springs i've seen only have the front eyelet reversed. hope this helps.
1 - 2 of 2 Posts
