Not sure if this is what you want. But its a start, The black wire from the batt. side of the Ign. switch is hooked to the batt. side of the light switch. The red wire is hooked to the same batt. connector on the light switch then runs to power the fuse block. Hope this helps Ron
looking at wiring diagram on fuse panel top left of it there is a wire saying "red-battery on light switch " where does this go ?
That red wire goes to several places. There is a splice inside the harness that connects the constant battery power from the voltage regulator to the headlight switch, fuse panel, cigrette lighter, clock, and glove box light.
