On my 57 210 I installed CPP 500 box. I Bought a 32 inch tilt column.
I bolted the column to the DD rag joint but when I went to install the column
below the gauge cluster it would not fit. The tilt part of the column did not clear the gauge cluster. I need about an 1 to 1 1/4 inches more to clear the tilt section of the column. I moved the rag joint out as far as I want to go on the steering box.
Has anyone else ran into this problem??
If so what was your solution?? Please let me know.....Tom
I did re-measure the column and it is a true 32 inches.
Ididit makes a retro column specifically for the 57 Chevy. I don't know what the length is but mine fit correctly. Flaming River also makes a 57 specific column I believe.:bowtier:
IDIDIT makes a DD universal joint that is used instead of rag joint and is longer overall than a rag. maybe long enough for your application. Go to their web site and look . also you can call them and talk to someone about your problem ,,, great people to talk to ......
1957 Belair wagon, 51 HenryJ
Probably not what you want to hear but I cut off part of the gauge cluster to clear the Monte Carlo tilt column on my 57. I did not have a concern as I have two more panels, but I no longer have any stock columns, good day.
