1 - 12 of 12 Posts
when using any high solids primer or even epoxy you need to keep the gun rinsed. if left in gun during flash time the solids will collect in the nozzle . this will slowly shut down the flow. ever seem like the second or third coat goes on dry ?? this is a very common problem with todays high solids primers. even 10 min of flash time will do it. the solids will not remix with the flow . it will turn your 2.0 into a 1.0 quick .
this is a trick i came up with years ago when i started using gravity guns. get a ketchup bottle or something similar . i bought these by the box back when i was doing more custom work and using my airbrush for colors. after a coat i empty the cup , wipe it out with a paper towel then insert the bottle full of thinner. pull the trigger wide open and flush the nozzle good. now i have a clean head ready for the next coat.
just food for thought and worth exactly what you paid for it . :anim_25:
Thanks. What do you do during flash time with base and clear?
i try to avoid base coat if i can but i do the same with anything. i have very long flash times for clear so i rinse it the same way. base not so much while shooting but if i intend to let it flash for over 10 min i will rinse. just got in the habit of doing it. takes less than a min to do . keep an old icing knife handy , makes cleaning the cup real easy .
i try to avoid base coat if i can keep an old icing knife handy , makes cleaning the cup real easy .
Just learning. I used Iwata 400, epoxy primer, primer, base (color) then SPI clear. Like the icing knife idea.
My wife just bgought a bunch of those.....hmmmm, I know where some are gonna wind up......:sign0020:
:gba:
bowtie-trifive
Thanks for the tips pd. I'll stop that very habit I have.
Thanks for another great tip PD! :)
Always interested in what you have to say about painting porch dog. I know very little. Thanks for the information. bowtie-trifive :gba:
well one thing for sure, i can sure tell you how not to do it . if it could be bent broke or screwed up i've done it .
STICKY PLEASE ADMINS
1 - 12 of 12 Posts
