1 - 16 of 16 Posts
Got the Caltracs ready and put the 9" under the car..Whoops! the backing plates on the 9" go over the housing end about 3/4" further than the stocker..
being that I made the 9" At 58"OAW, I now have a "press fit w/ the outer shackle bolts and the edge of the spring plate.
Should have done the spring pocket kit while the frame was on the roto and unpainted!:mad::mad:
It's a real challenge w/ the car nearly done and me working upside down.
SURE AM GLAD I have a plasma cutter! [Even if I did burn a nice hole in my ribs!]
Oh well, This just reaffirms that Murphy lives here!:frown:
It appears that
Chuck i thought that was just the way it was supposed to go.:D
you are correcto!!!:biggrin:
Off to the parts guy for a "pocket kit". i think they call it a pocket kit, as they get in your pocket when you buy 1!!
Hindsite!! is always 20/20, For years I thought standing on your head was the only way to work on these cars. Life is good and we make do. So post some pics and good luck.
Ran into the same problem with my narrow 9" and big ford drum brakes. couldn't get the u-bolt slid past the backing plate e-brake cable humps. Rear disk brake kit solved the problem. No cutting necessary,,but a extra $400 spent. really wanted rear disk anyways,,,lol.:)
Then there's Murphy's brother Stanley, occasionally he'll smash your thumb and cut your hands and fingers, but otherwise he's pretty handy. :eek:
It must have..
been Stanley that burned the hole in my ribs! His brother was too busy making problems w/ getting the brkts measured up..!:biggrin:
You can buy steel and save by building your own.
Discussion Starter · #13 ·
FINALLY!!
Got the pockets in and welded...Even avoided being admitted to the IC burn unit!
Got 3 NASTIES out of the deal, including a couple "dingleberries" in my ears.
Sure makes the sound of searing flesh easier to hear!:eek: [Even melted the outer end of my ear plug....]
NOT nearly as "pretty" as doing them at the right time. But, they are in, and a bit more grinding and some "frame in a spray can", it's as good as it's gonna get.! [Can't see them at 80mph from the other lane, on the interstate, anyway!]:biggrin:
Chuck....Some more hindsight.....Never been there and done that.....Just thinking out loud here.....A thought just occured to me (Danger, Will Robinson} If you went to disc, could you have avoided needing a pocket kit?:confused0006:
I just checked my garage... I think some of Murphy's personnel belongings are still in my garage. Should I ship them to you address. Nevermind... He'll be back!!
FINALLY!!!
I did the minimum on the grinding, and applied a couple coats of "frame in a can"...All is as well as it's going to get!
1 last "tweak" was in order...The kit is made w/ 1/4" box material..:eek:
And, due to it's thickness is a snug fit w/ the Caltracs. Of course, Murphy was helping me and I had to "pooch" the pass side out, just a bit.
Murph had used the porta-power last, and blew the seal out of the head unit...:frown:
Never fear..1 of my trusty "inventions" came to the rescue! A 5/8 bolt screwed into an all thread connector nut, made a perfect "jack"...2 shots and all was gtg! [Sometimes I scare myself w/ being overly cleaver!!]:biggrin:
Rearend is in, u-bolts cut to length, hsg aligned and centered. A measurement comparison:
Outer fender lip to wheel mt face w/ stock axle = 7".
W/ 9", [cut to 58"OAW], in place = 8".
Now, the fun comes... Getting a wheel sized to fit:
The plan is Billet Specialties Streetlites. 17 x 7 ft,[215/50], and 17 x 8,[255/50] or 9.5 on the rear. Most likely 8" on the rear w/ a bit less b/s for a bit better look..IMO, the 9.5" wheel would need a 275 tire to look right, and may be a "press fit". Y/N??
Need to take a day or 2 on "easy street" to let the bruises and burns calm down a bit! So, I'm off to the Chevy store to spend some more of my kid's inheritance$$:smile:
1 - 16 of 16 Posts
