1 - 14 of 14 Posts
· Registered
Has anyone made their own adapter using a regular jack. I'm thinking 3/4 plywood, 2 by 2s for cradle and couple of small chains.
looked at a 50 buck HarborFreight adapter, but lift height is high and it's geared toward specific jack size.
· Administrator
I used a square of plywood on my floor jack for a long time before i bought a trans jack to use. Didn`t even use chains on the plywood, just a balancing act.:D
· Registered
If you have a removable cradle with a 1-3/8" stem, this piece works really well. used mine a few times. As you can see,,one end is open so you can push/slide the trans forward for bolt up, and the sides are lipped so it cant work itself off to the side.
http://www.jegs.com/i/TCI/890/896500/10002/-1?CT=999
· Registered
I didn't know this exisited...until now. Should mate with my TCI TH400. I see it's on Ebay, Summit and Jegs all for about the same price. Mike
· Registered
Hey Mike..12" x 12" piece of steel plate..two rachet straps..a rubber mudflap and a old jack head..15 mins of cutting/welding and presto.. i was in business :)
Copied from the TCI cradle..i had most of the materials laying around the shop.
· Registered
Yea, Mike, got a garage full of tools and parts...except a welder. Anyway, "Tim the Tool Man" is always willing to get a new tool, right?
· Registered
· Registered
Had a 700R, deep pan 350 and 400 on it, plenty of room. check your stem size before clicking "buy" if you do decide to go this route.
1 - 14 of 14 Posts
