1 - 19 of 19 Posts
I made the homemade master cylinder pressure bleeder yesterday, applied 20psi, and it worked 2 times then, I got sprayed as the rubber was to thin, as well as the plate thickness to thin. Making a new one but does anyone know where to get rubber I looked all over and no one has any in there store. Thanks.
I have an old inner tube around that I used for mine.....If you can't find what you need, send me a PM and I'll wack off a hunk for ya.
How thick was your plate, BTW.....I wouldn't go any less than 1/4"
Just had 20 gauge around, going to machine shop tommorow for 1/4 aluminum, I have a inner tube I bought but didnt think that was thick enough, but if it work for you, then it must work.
Mine is a auto inner tube, not bicycle....So, its probably thicker.
Back in the day you could get rubber in sheets of all thickness, crazy all we have now is inner tubes.
Try McMaster-Carr's website. They have rubber sheet in just about any description you'd want.
EPDM is a rubber compound that won't get eaten up by rubber. It's what the seals are made of.
The harder the rubber, the less likely that pressure will distort a gasket.
Containing a gasket with a step on the sealing plate will help.
Last thing, why use 20 psi? That's really a lot. Try 5 psi. Use a bicycle pump or a pump for a basketball if you can't control the pressure.
Use your head and you can get there.
Great thought Rick I can dial my compressor down to 5 psi, and try new rubber thanks for all the info.
Just a thought here for you, go to a local landscape company that sells pond supplies. They will have pond liner that is 4 to 5 mil thick, that should work good for you, it is edpm rubber. I have a nice backyard pond and this is what is used to build the pond. They also sell it in small squares for repair to your line if needed.
Here you go - neoprene - Not very many chemicals effect it.
http://www.mcmaster.com/#=n6mcyo
Try Lowes. I was in Lowes recently in the plumbing section and they had some sheets (maybe 6" square or larger) of, what I guess, is rubber gasket/seal material. Don't know what kind of rubber it is but it is pretty thick.
AJ....Before using my bleeder, I glued the rubber to the plate.
Plumbing supply house. 1/8" rubber sheet gasket material. The red is normally std. rubber, the black reenforced rubber.
built (and used) my cover today. used a piece of 1/4" steel plate. Drilled a 3/8" hole in the plate and welded in a 1/4" air disconnect to plug in easily. ground a groove in the plate where the fluid could go from side to side with no problem, notched the gasket on same area. Couldn't find a piece of rubber lying around so cut a chunk from an old "doggie door flap". Yes anything pliable that isn't effected by brake fluid will work. Was about 1/8" thick. set the plate and gasket on top of cylinder and attached with two c-clamps.
Everything worked great, not a drip. Now have a great brake pedal!!!
Sounds like you made yourself a very useful tool Warren. :):congrats:
Discussion Starter · #18 ·
Ouch
I found rubber at ACE hardware store 6X6 inches in a pack of two glued it down, first bled master, and have beed bleeding for long time only have about 2-3 inches from floor, cant seem to get it any better.
I was told pressure bleeder would force air into the system by an old brake guy he told me to gravity bleed, tried that to no aval.
Also I have a blinking Dakota Digital on the temp, any way to reset it? Thanks
My pressure bleeder (bought from an auction $20.) is a tank with a bellows in the center. Fluid on top, air in bottom. No way to get air into system (well, unless the bellows sprung a leak). Holds a gallon of fluid. Keeps pressure on the entire system while bleeding. Takes about 10 minutes to do all four wheels (twice). I run a clear hose from the wheel bleeder to a plastic container and watch the air bubbles move out of the system!
1 - 19 of 19 Posts
