Since I took out the ballast resisters the horn only works when the car is running. The horns worked before with the car off. There was a green, brown and white wire going to the pos side of the resistor I connected them to the pos side of the coil. I have tried every combination of wire hook up but cannot get the horns to work until the car is running. The horn relay has a constant 12v Any suggestions? Thanks in advance.
