Hello everyone i would like some knowledge on what size tires and wheels i can run, what will a stock 57 belair hardtop rear accept in wheel offset and total width tires ? i know someone musta tryed some combos i am thinking 4" backspacing on 10" rims with P325/50/R15. anybody know if these will fit "without cutting" under the car please help? i will be back at 11:00 going to take the family to the ERIE County Fair See ya later
The biggest I could get on mine is 275x15x60 and have 3/4" on each side with a 4 1/2"x8"x15" rim, thats with no frame or tub mods
I have a '56 210. I just put a kit in it to move the rear springs inboard. The original spring perchs were 4 1/2" from the backing plate and I moved the new perchs in an additional 3 1/2" from the backing plates. After doing the springs you need to move the inside of the wheelwells in to the edge of the frame for clearance.
Dave
Big Tires
Thanks for the help saved me some trouble i would a had still i like to hear more about the inboard spring kit idea.
I am using 245/60X15 on 15X8 stock Corvette aluminum wheels. That gives me 3/4" clearance to fender lip, with rear disc brakes on a stock rear-end.
