got the new glass for the vent windows how do i change them friends thank you
You will need to remove the vent window assembly from each door and then replace the vent glass in each frame. There is an excellent article on the Danchuk website that explains step by step how to tackle the job. It is in the "Newsletters and Flyers" section and is number 7.1. It isn't too hard and remember to have some water and dish soap handy to mix up as a lubricant for the rubber. Good luck!
Must remove vent glass from door. The easiest way to get the glass out of the frame is to heat up the chrome frame with a propane torch with the glass held in a vice. Have a friend help you. Pull the glass out of the frame evenly so it doesn't jam and bend the vent frame. May want to use some rags so you don't burn yourself. Clean the frame of all residue from the orig glass setting tape. Installing the new glass is a little trickier. Will need glass setting tape. Stretch it around the glass without tearing the tape. Again you will need assistance when inserting the glass in the frame. One person holds the frame the other holds the tape onto the glass while it is being pushed in. Slide the glass in evenly so it doesn't bind. May want to use a rubber mallet to help to drive the glass with tape into the vent frame. Cut the excess tape away. May want to use a razor blade to trim away the visible tape.:anim_25:
