Possibly, was there any air in the master cylinder?
I honestly don't know. The car sat with shot caliper seals for quite a few yearsPossibly, was there any air in the master cylinder?
Thank you.Sometimes air hangs out in calipers. Hit you calipers with a large plastic hammer around the sides and let it set a while. See if you get anymore air out. If you let the M/C run dry, it might be aIA without a pressure bleeder.
I have found (through many failures) that this method: DIY Pressure Bleeder or a Motive Brake Bleeder work better.I am doing manual bleeding with a 2nd person, and going from the farthest wheel to the closest.
I always start at right ft and work my way around.I am doing manual bleeding with a 2nd person, and going from the farthest wheel to the closest.
Interesting on making it level! I had not heard that before. At this point I'll try anything. Don't understand how this car's brakes are so different!!I recently sold a C3 Vette that I had owned for close to 10 years and brake bleeding that car was far different than anything else I had owned. A power bleeder is your friend with a Vette and lifting the rear end of the car so the master is level was another great tip that I found out about.
May I ask what the theory is behind that? I'm not being sarcastic at all, just never heard that done before.I always start at right ft and work my way around.
the are not that difficult. you just have not bled enough. its not how many trips around the car it how much fluid you push thru at each corner. as other have posted a pressure bleeder is your friend.Interesting on making it level! I was always taught you wanted the MC higher! At this point I'll try anything. Don't understand how this car's brakes are so different!!
no theory, just the way I have always done it and never had a problem.May I ask what the theory is behind that? I'm not being sarcastic at all, just never heard that done before.
Make sure you put a short bubble level on top of the master cylinder to get it perfectly level. The logic behind this is that on a C3 the master cylinder is greatly tilted up in the front and this allows for an air pocket to form and that will cause brake bleeding issues with the air pocket that you can't get rid of.Interesting on making it level! I had not heard that before.
A vacuum bleeder is about 30 bucks and is handyThanks all for the info. I'm not sure if I am willing to spend 60 bucks on a pressure bleeder that will sit on my shelf forever once I'm past this debacle. I also don't have the gift of making one out of a garden sprayer, so I'll have to ponder on that one![]()
