Was it a Motive Power Bleeder?
Was it a Motive Power Bleeder?Tried the pressure bleeder and I failed. It started so well. Even with fluid in the jug, the rear reservoir still drained out completely. The pump also broke at 12 psi.
I tried to reach out to a "Corvette specialist" that I saw an ad for online, but they don't do house calls and are too far away. I don't know why this car needs to be so challenging.
I'm not sure who manufactured the Summit but my Motive has never failed me. I clamp the plate over the master cylinder using a big C-clamp instead of the chain and hook sent with it. I bleed one wheel at a time then top off the reservoir. I have never put brake fluid in the bottle. This routine has never failed me.No, the Summit one.
usually operator error.Tried the pressure bleeder and I failed. It started so well. Even with fluid in the jug, the rear reservoir still drained out completely. The pump also broke at 12 psi.
Interesting. Had I done it your way I probably would have been fine. I'm going to see if I can exchange mine for a Motive one.I'm not sure who manufactured the Summit but my Motive has never failed me. I clamp the plate over the master cylinder using a big C-clamp instead of the chain and hook sent with it. I bleed one wheel at a time then top off the reservoir. I have never put brake fluid in the bottle. This routine has never failed me.
Summit has the best customer service andI think they will work with you. My best to you!!! ElijahInteresting. Had I done it your way I probably would have been fine. I'm going to see if I can exchange mine for a Motive one.
That's what I have, the air powered vacuum. has never failed meI would get an air-powered OTC vacuum bleeder. I've been using one for 20 years and it works great, even bleeding a complete dry system on several vehicles. I have a Motive pressure bleeder too, which is needed on some newer vehicles, but on stuff like you are working on the vac bleeder has always worked first try. There are many other little tricks I've learned, like using a bottle of brake fluid stood up in the reservoir to auto-fill it while bleeding.
patience grasshopper---you can do it.I'm going to have to pay someone for this job I think![]()
This is exactly what I do except I pressurize to 15 psi., so now I just use it to pressurize the system and push the fluid through being careful to not run the reservoir dry. It only takes about 5 lbs. of pressure in my case.
Good to hear progress. That valve should re-center itself when all the air is gone and the pressures equalize again. Looks like it is the case if it is going off. Sometimes they get stuck.Def getting better. That light has been going off. No leaks. Looks like I will need to go around again, though.
