1 - 16 of 16 Posts
1955 BelAir 4-Door Wagon, 350/350
I'm currently priming, wet sanding, priming, wet sanding, priming and wet sanding my 4-door BelAir wagon. I'll be sealing it with white sealer (already bought). I plan to paint it a 'yet to be determined' shade of solid red (no metallic). My question is, how much paint do I need to buy? I'll be doing the underside of the hood and all the door jambs, as well as the outer body. I know that red is one of, if not the most expensive color, so I'd like to get a better idea of how much to buy, so I don't have a lot left over, and don't run out too soon! Your thoughts?
Regards,
John
Thanks Porchdog. Can you give me an idea of how much I might need to do a wagon? I know it depends on a lot of factors, like # of coats, etc, but I'm interested in anyone's opinion who has painted one of these 'longroofs' before. Thanks, John
2 gal min. i buy 2 gals on every job . mix it together well and pour into qrt cans . last qrt in a gal can is useless . i'd rather have 1/2 gal left than have to buy more and risk color match .
RIP: 10-27-2018
I used about 2 gallons on my 55 belair wagon (one gal ivory, one gallon tuquoise) but I ended up ordering a quart of each extra since I color sanded it so much and re-did boo-boos.
Of coarse one factor is making sure you have enough items to paint to use up everything you mix. Nothing upsets me more than to have to throw out a quarter gun full of paint because it has hardener in it and will set up in the gun. I try to have extra trim pieces etc hanging around that need paint if I have some left over. The down side of that is running out of paint just before you finish a coat.
Also get yourself a nice step stool you can move around the car as you paint the roof. I am tall but its hard to reach the middle of the roof.
My big sin is draggin the hose through the paint . I run it over my shoulder and clip it to the back of my belt.
Banned
Regards,
John
You did`nt say single stage or base clear.
Sorry, 57. I plan to use Base / Clear. My buddy is going to do most of the shooting, as he has quite a bit of experience. He wasn't sure how much paint we'd need, as he's never painted a station wagon before, and paint is so dang expensive!! Thanks for the replies so far. More opinions and advice are always welcome!
Regards,
John
I shot single stage paint on my '56 wagon. Used 6 qts. of yellow on the body and 2 qts. of white for the top. Had plenty of paint on it so that I could color sand it.
I would reccommend ditching the white sealer and getting a color tinted sealer to match your base . some of the basecoats these days are a little thin and transparent to a point and a color matched sealer will help even the color out.
Banned
Regards,
John
Do you cars longevity a favor............lots of clear for cut and buffs and paint corrections down the road.
A rule of thumb my painter used is "a pint per panel," using the hood as an area from which to measure say for figuring a station wagon roof, then rounding up to the next pint.
For example, a '55s Convertible Shoreline Beige upper rear panels would be a total of 3 pints (1 pint for trunk lid, 2X ½ pints for upper rear fenders), then rounded up by a pint to 1 quart.
The Gypsy Red requirement would be: 2 doors (each panel being a pint), 2 front fenders (each being a panel needing a pint), 2X ½ pint for lower rear fenders (coming to 1 pint), and the hood being another 1 pint.
So the total needed for Gypsy Red is 6 pints (or a need to have at least 3 quarts), but since it's the primary color, round up to 4 quarts.
This shows that a paint job (including two-tone) would be at least 5 quarts as a minimum requirement.
We used CC over BC in a two tone. India Ivory over torquise
1/2 to 3/4 gallon on the India ivory
3 gallons for the torquise
:anim_25:
Flaw to that logic is the hood is twice the size of the door. Don't forget fender extensions, splash apron, etc. Also some colors are tranparent and wont cover in 2-3 coats. I have have some take 6 coats to get coverage.
1 - 16 of 16 Posts
