If the DTM urethane primer can be used to build up the surface, then you are fine with that. I would also make sure the maker of it advises it can be
used over straight epoxy primer. Some DTM primers are not intended to be used over anything else. If the DTM urethane is a high build, there is no
advantage to using a polyester primer. These are harder to use and are reduced with lacquer thinner that can make them hard to control because
lacquer thinners no longer come in different temp rating. Urethane solvents come in about 4 different temp ratings for use in different temps.
I use only one body filler All Metal and can spread it as uniform as any glaze.
