Hi there,I have a 57 2dr sedan that I would like to tub out. I already have the 4 link parts for it and the roll cage. I was only going to do a mini tub with aftermarket steel tubs but the floor is bad on this car also. Can I cut the entire floor out and lower the body down on the frame some so it will sit lower? I would also like to use the original frame in the rear and just cut it and move it in 5 inches on both sides. I would just put 2x4 steel tubing out to the A and B pillars and install my own steel floor. Does this sound like a good idea or bad idea. Any input is great thanks.
