1 - 11 of 11 Posts
I went to install the driveshaft and I'm not happy about the yoke depth. I would like to get another 3/4-1" and there is no way to do it without making the driveshaft longer.
Anything to take more time and cost more money.....
Don
If you get the tailshaft lengthened it will have to be rebalanced.
Is that a standard length you have?
You dont have many choices either the trans goes back & you know what that means or you stretch the tailshaft :anim_25:
Good question....
Can you buy a longer yoke?
I thought of that but I'm not sure what's available. I have a 700R4 trans and I believe the yolk may be the same as a 350 turbo. I will have to do some searching.
Don
Why not search around for a longer driveshaft?:anim_25:
:bowtieb::bowtier::bowtieb::bowtier::bowtieb:
Check also where the splines start inside the yolk. They are not all splined full length and you may have even less engagement than it would appear from your photo.
I am starting to find different length yokes on the innerweb.
It's a 27 spline and I believe that is somewhat common to several applications. I believe it is the same as Muncie, Saginaw, BW, and some others.
What I have now is a nice balanced 4-1/2" shaft the PO put some bucks in with the Spicer joints and it is all brand new. The last two shafts I had made were over $500 each. I'm trying to avoid that this time.
I am going to the local NAPA today and a friends shop that does not throw anything away.
Don
1 - 11 of 11 Posts
