Ignition Switch
TooBadBrad said:
I used to know, but can't remember, how do I get the tumbler out of the switch so I can remove it from the dash? Also, what's the trick to remove the headlight switch?
Brad
Hi Brad... my english is not good but I expect that be understood.
To remove the headlight switch, just pull the knob to lights on, in this position, push a little "button" located in the top of switch (in the oposite side of conectors), and pull again the knob until you can remove it.
With the knob removed, using a wide and flat screwdriver, unscrew the headlight switch bolt and you can release the entire switch.
Brad to remove the ignition switch put the key in and insert a pin inthe small hole and then turn the key and it should come out. I use a big paper clip for the pin. Terry.
Senior Member 4 Gold Stars
Both good advice. On the ignition you need to put it in the lock position, put the paper clip in and push on it. You will feel the spring action going in. Once you feel than, turn the key farther to the left and it will sort of jump out.
