So I had my 56 out for a drive today, came home left in the driveway for about 1/2 hour, went out to put it in the garage, it started up just like always, after putting in garage, I cannot turn the key to the left to cut it off, so I raised the hood thinking after unhooking the battery I could maybe turn key to start, jiggle it and get it working again. No such luck, key will go in and out, but will not turn right or left. I have read some posts on forum about this, but looks like everyone has taken a different approach, is there one best approach that works ?
Thanks in advance !
Is it an old switch like the original? The dimples on the contact plate may have worn through and is catching on the edge of the contacts. You may have to force it to the lock position to get the key tumbler out to change the switch.
Discussion Starter #3
My switch is not original GM, but is aftermarket from Ecklers, maybe 9-10 years old. Could have same problem as you describe, I plan to spray some PB blaster in, to maybe loosen something up, before I get more physical.
Thanks for the reply !
The problem is it is an aftermarket switch - they have nothing but problems sometimes shortly after installation, sometimes years later. Originals rarely go bad, it is such a simple design. Gm made them very well, China, not so much.
You will likely have to force it to off & lock so you can take it out for replacement. I'm honestly surprised you got 9-10 years out of one of those POS switches. Do yourself a favor and get a genuine Delco switch, They are on Ebay all the time.
Discussion Starter #6
These Delco switches are used GM or do they still make new ?
I found a new old stock ign. switch still in the box for my 56 last year on ebay think it was around $100 but worth the difference
They are not made any longer by Delco. There are still NOS switches around and the part number is 1116512.
