Good Evening All:
Just finished the install of a new 6 bladed fan and fan shroud. What a difference this made. Engine running 160 - 170 degrees. Lots of modifying to make the shroud fit but I am very pleased with the results. Check out my new pics in my garage of the finished job.:party0031::party0031::party0031:
Cool!!!
Looks Great! Good job! :)
looks very good. i thoughy my temp was good. good for you. where`s that shroud from?
Hi Hhdude: I bought it from Mutton Hollow but Ecklers and Danchuk carry it as well. It is for a V8 rad in the six cylinder position. I had to trim and notch the lower part and the sides a little bit and redrill the side mounting holes but all in all went pretty smooth. The results are better than I expected.
The shroud is made out of ABS plastic, I used a jig saw with a fine blade and my dremel tool with a metal burr to do my sculpting!!
It turned out very good. Sounds like all the modifications i went through too.
Hddude it looks like the same plastic shrouds that all the vendors carry.
Hi Terry:
The install went pretty well lots of putting it in taking it out until I got it just right. Thanks again for your help. Lower rad hose is a little tight to get at but no worries.
