1956 Belair Sedan, Resto-Mod, Many Upgrades
Struggled with this...so I made myself up a tool to do the dirty deed.
Those GM firewall pad holding grommets are a PITA...
This is the tool I made up to push those puppies in place, replacing a pad in my neighbors 63' C-10...not pretty, functional.
I used a 1/4 stove bolt, a 1/4 fender washer, a washer for an old shock, and a barrel nut (1/4 X 20)...the spot welds are just for holding it all together.
I also used it this way: I adjusted the stove bolt so that it would be slightly longer than the grommet, heated up the grommet with my heat gun, tapped it in with a rubber hammer, then finished driving it home with a 17mm 3/4 socket and 12 inch 3/4 drive extension.
It worked...for this old guy!
Metalworking hand tool Cutting tool Tool accessory Tool
Auto part Tool accessory Metal Machine Steel
Metalworking hand tool Cutting tool Auto part Tool accessory
Not sure how the shock washer plays into the grand scheme of things :confused0006:
It provides a perfect surface for the grommet as the head is concave...as is the washer. It spreads the load lets say...a flat washer would only contact a little surface. Plus it can take a lickin and keep on driving without bending like a fender washer will.
Got 'cha Neat tool :):tu
