Yes, the 3 legged retainer goes through the large holes in the belleville spring.Thanks guys, finally got the horn parts installed. But shouldn't the three prong insulator pass through the metal disc's round holes so the metal disc would float? And no, I don't have electrical power connected to test.
That's what I thought but the three legged prongs are too short for the spring, should I file the plastic washer down for needed clearence. Should the spring float on the three legs? I realize my description is horrible but that' the best I can do.Yes, the 3 legged retainer goes through the large holes in the belleville spring.
The spring doesn't actually float. It should provide just a slight pressure to the horn ring to keep it from rattling. It's best to shim the 3 legged retainer with some plastic washers. Glue them to the 3 legs after you figure out how thick they need to be. If you cut the notched plastic spacer down, it may not allow enough movement of the horn ring before it contacts the steering wheel spokes, to compress the spring.That's what I thought but the three legged prongs are too short for the spring, should I file the plastic washer down for needed clearence. Should the spring float on the three legs? I realize my description is horrible but that' the best I can do.
CJ
Yes, that's what you need. The original shaft was part of the box and grounded to it.After beating my head against the fender trying to get my horn to work! My steering shaft is not grounded. How is the shaft grounded? Should/can I use a ground wire from steering shaft coupling to steering box coupling? Sounds like that should work??
CJ
