Connector on top of intake leaking. Tried the teflon tape / no help What sealer would you recommend that would hold up the best ? Thanks.
The teflon tape should have taken care of it. If you have an aluminum intake make sure you don't have a hairline crack at the tapped port for the fitting, I have seen it before from the fitting being over tightened.
I was thinking of that also...for $10 or so..change it for peace of mind and maybe less work in the long run Thanks
You really only have two options, Teflon tape or thread sealer, look a bit closer to see where its leaking from.
