Have you tried checking at the tailpipe with your hand to feel the amount of exhaust coming out both when it's running correctly then when it is acting up that might indicate if there is a restriction in the exhaust. Years ago the factory used a double wall exhaust pipe & I have seen the inner wall of the pipe collapse restricting the exhaust same as happens today when a converter is plugged.I seriously doubt that is your situation as It's likely yours wouldn't have that type exhaust plus it wouldn't come & go with engine temperature but might be worth checking the exhaust output based on your observation .
