In addition to a TH400 trans. needing a vacuum line, does it also need a kickdown switch?? Is there a difference on the front yoke between a truck 400 and car 400 trans.? Does the yoke on the truck trans. get bolted to the rear output shaft?? Can the truck 400 be used in a car application. Many thanx, Carmine.
The later model auto transmissions like the turbo 350/400 use a vacum line thats connected to a modulator mounted on the pass side of the transmission.
The T400 does have an electric kickdown switch. It can be pedal or carburetor mounted. The long wheel base truck/suburban, having 2-piece shafts, have the fixed bolt-in transmission yoke. Unlike a car where the spline slip joint is located at the transmission output shaft, the LWB truck spline slip joint is provided at the bearing at the center of the shaft.
Carmine, You can use the truck TH400 but not the bolt on yoke. You need a passenger car slip yoke and you will be OK. The truck (3/4 ton and larger) TH400's usually have a deeper pan and a heavier duty case. The switch is something you don't "have" to have but is recommended for optimum performance and probably easier to hook up at the carb.
Yep... Passenger side front near pan has vacuum line for up shift... Driver side to rear of pan you'll see a single lead solenoid that wants 12 v to tell it to down shift. Switches are available on summit to rig your carb for it if needed
Thank you for all the responses. As you can read in another thread, I'm looking for a TH350 or 400 trans. There is a junkyard real close to me and they have 2 TH400 trans. that came out of I believe pickup trucks. They both have a yoke bolted to the rear output shaft and I wasn't familiar with that. It's good to know that they will work in my car if I get the passenger car front driveshaft yoke. They want $300.00 each and are suppose to be good transmissions. They also come with the converter. Still undecided at this point. Thanx again, Carmine.
To use with a regular driveshaft you will need a yoke like this guy sells.
http://www.dennysdriveshaft.com/p69...sion_slip_yoke_1310_series_32_spline_wth.html
I had 68 Chevelle I once, that put a TH400 in that started life as a stick car. I put the kick down switch on a toggle switch on the shifter. You could then cruise down the street and shift to low with the switch.
