1 - 20 of 29 Posts
Have asked myself too many times (after) I am almost finished with Classic update kit why I put the fuse panel back in stock position LOL. or at least didn't install ALL fuses first. Going to start testing today before I tidy up the wiring behind dash and not fun .
1957 Bel Air sport sedan
Have the fuse layout schematics?
well, got all the fuses in...everything works EXCEPT dash lights. Fuse is hot but gray wire feeding is not....tested it on bench when I redid the speedometer and the green lenses for turn signals. signal indicators work so ground is good. Where to look??-----------------------------------
Never mind---brain fart---turned off at headlight switch LOL
Go and search your local yard sales some weekend and grab someone's unwanted weight bench for cheap. My guess is a little modification could yield a workable substitute.
I've used bare plywood but I also have a big exercise thing with weights, cables, any pulley's that I'm going to scrap. I'm sure I'll find a way for the bench part of that to do the job.
1 - 20 of 29 Posts
