1 - 11 of 11 Posts
member
I did all the bodywork on my Nomad in lead in the early 80's. I was going to re-do it all in lead when I replaced my panels, but I convinced myself that the new fillers are just as good. Lead bodywork isn't that hard to do, just more expensive and time-consuming. Lead isn't that easy to get anymore like it used to be.
I used lead on my '56 (finished in '92) because I wanted everything done as it would be new (painted in Nitrocellulous Lacquer also).
My '55 I've started working on will use filler (very little I hope) but I've had a lot of success if used properly.
For a second there I thought you said Nitrocellulose lacquer (a flammable liquid used primarily as a binder in fireworks compositions) :vroam:
"For a second there I thought you said Nitrocellulose lacquer (a flammable liquid used primarily as a binder in fireworks compositions)For a second there I thought you said Nitrocellulose lacquer (a flammable liquid used primarily as a binder in fireworks compositions)"
So far the car hasn't blown up. Yes, all original lacquers (and GM) up until 1957 used Nitrocellulose lacquer. Can still be bought in mixed colors.
Checked the Eastwood page, obviously I can see only the most serious bodymen are going to use lead.
So for the dumb question of the day since I haven't 'bondoed' in a while...what's the preferred brand of plastic filler these days? I'ts just a small area I need it for.
I guess I answered my own question, surfing the web, lots of info out there,
for example:
http://www.roadsters.com/filler
1 - 11 of 11 Posts
