1 - 2 of 2 Posts
In my 57 I have a cluster with LED lighting. I recently added a pot that lets me adjust the brightness of those lights. When brightness is set to mid-way the cluster lights flash on and off when the turn signal is on.
I have installed an electronic LED flasher unit as well as replaced all the incandescent signal bulbs with LED plug in bulbs and it is still doing the same thing.
I have heard that I may need to put a relay in to separate the light power from any voltage drops, but wondered if anyone else has suggestions, or recommend a relay to use.
1 - 2 of 2 Posts
