1 - 12 of 12 Posts
Im intrested in mounting my alternator low. I know there are some issues ive seen with the alternator hitting crossmember. Has anyone used a mini alternator or notched the crossmember? any pics or info would be great. ive got a 350,with fenderwell headers,forward side mounts, thanks..
Has anyone used a mini starter or notched the crossmember?
Did i miss something or ??????. I thought you were talking about the alternator. :D
I tried a 60 model chevy low mount bracket and it hit the crossmember.
I just tried to use an alan grove low mount and it did not work. I have 3/4" forward motor mounts.
Discussion Starter #6
yea good catch.. i changed it,, looks like everybody that tries this hits the crossmember..
Yes, I originally had an alan grove mid-mount on the passenger side and it worked great. I only moved it due to adding A/C.
mine is on the drivers side. i can use a small alternator or a 1 wire GM unit. I will try to get pics tomorrow. Its all home made but very simple.
Did you retain stock fuel pump with this
setup?
Yes, I am running an edelbrock mechanical fuel pump and a one wire alternator with the mid-mount bracket. See pic below.
1 - 12 of 12 Posts
