1 - 14 of 14 Posts
Ok guys i am planning ahead for a LS engine swap. What are yall using for the exhaust manifolds? The engine i am going with is the truck/suv 5.3. Need to figure out and decide whether to use the stock manifolds, if possible, or find which headers work. Still have the trans frame horns in mine.
I used the stock manifolds on the 6.0 truck engine.
I milled the dr side manifold at an angle, to get added 500 steer box clearance.
I cut the flange .080 at the top, & .150 at the bottom. Still plenty of meat to bolt it up, using the MLS factory gasket.
I also spent an hour w/ the 4.5" grinder and cut the "nubs" off, polished the castings, and had them ceramic coated.
I also re-used the stock head pipe flanges as they have a neat o'ring seal arrangement. The rest of the system is 2.5" s/s tubing, hooked to a Pypes exh/x pipe set up.
You make life alot easier for yourself with alot more choices if you lose the frame horns...
Charlie
I have a set of cast iron manifolds from a '99 Silverado truck with a 5.3, if you're interested.
I bought a wrecked tahoe with a 5.3, complete so i have the cast iron manifolds. That is why i am planning ahead. Thanks Laszlo for the thought.
Sanderson headers were the only ones I could find that would clear my steering box. They're shorties and probably not much better than the stock manifolds but those wouldn't fit.
do you guys think the stock 6.0 manifolds would clear the original steering box? im using cpp side mounts and the adapter plates from fleabay.
LS-1
Try calling Mark at S&P Performance. He has most of the parts for this swap 479-394-5711. Tell him Michael from Portland sent you. He is the owner and very Sharp !! I used his headers.
Be sure to let him know if you are intend to install a Rack & Pinion steering set up, the header are different. Try Dutchman's Motor Sports in Portland for the R&P or rear end / axle needs.
He is usually swamped his calls. So if you have to leave a message, leave
it with Dorina, she will make sure he gets it.
If you install a Tremic 6 speed let me know. We have the Hydraulic Clutch
kit with a modified Vette Master cylinder. The LS swaps are a bit of work but it will be worth it.
Questions, send me an email, be glad to help out.
Michael......................
Discussion Starter · #13 ·
How good are the Sanderson headers?
Sanderson headers are generally known as top notch products from everything i have read on them.
55delray:
Can't answer your question directly. but I can show you some pics of my 2002 LS1 (5.7 litre) with stock manifolds, in a 57 frame, with custom made side mounts and a CPP500 steering box. It was a tight fit...
I am not running this whole setup anymore...as I've moved the LS1-T56 into another tri5 LaszloBilt frame with a C4 rack and pinion setup, and gone to long tube headers.
but these pics are what I started out with, when I bought the Nomad about 3 years ago. It did fit...but the clearance from the exhaust manifold to steering box was about 1/8 inch, and the O2 sensor was hitting the steering box...
1 - 14 of 14 Posts
