1 - 13 of 13 Posts
Can anyone recommend any LS1 books/manuals please?
General service and maintenance and up to date performance upgrades.
What specific informaton are you seeking? There are some real good ones and then, some crap.
Chevynut that's superb !
NickP I'm new to LS1's. Intend to run my car virtualy standard to begin with, but modify for more performance as funds allow.
Tri Five forum is unbeatable but I do enjoy a bedtime book
Lazlo,
That is a great link. Thanks!
57 to LS1
UKfive7
I'm kind of in the same boat your in. Where do you start? I finally decided to go with the LS1 and the 6 speed. The donor car is a 2000 camaro. I'm sure someone out there, maybe?, has a step by step procedure to remove and install. I have the frame and suspension finished. Now is the time to remove the LS and 6 speed fom the camaro and than install in the 57. I've seen some kits, I think from CPP, that offer the engine mounts, headers, oil pan and trans mount all in one kit. Has anyone used this one? Also I plan on installing a power steering gear box, maybe a 500 series. I heard there might be an issue with the header clearance? Any help would be greatly appreciated.
ranger57
Not a book but a very informative forum.
Caution..Strong language and Adult content..:anim_63:
LS1 tech
Jim
UKfive7
ranger57
Hi ranger57
Think a lot of your questions are covered in the stickys at the top of the LS page. Certainly a good starting point.
As Jim pointed out LS1 tech is handy. Check out the hybrids section.
For my bed time read I printed out chevynuts pdf and ordered up a late print of "How to Build High Performance Chevy Ls1 byWill Handzel;
Thanks Paul.
I've not done an LS1 installation but may sometime, so I bought these two books.
1. "How to Swap GM LS-Series Engines Into Almost Anything", by Jefferson Bryant. ISBN-13 978-1-932494-81-5 Item SA156 Published by SA Design
2. "How to Build High-Performance Chevy LS1/LS6 V-8s" by Will Hadzel
ISBN-13 978-1-932494-88-4 Item SA86 Published by SA Design
Both of these books have some really good info, but are a bit short in a few areas, and they have a couple of mistakes here and there. So anything that is critical to know or that doesn't make sense needs to be backed up by another source, like asking here. There have been a lot of good posts here, ls1tech.com is another one, and chevynut's link looks good too. And you can always ask. There are also many good vendors out there who can help with parts and info.
I read the pdf from chevynut. There was a lot of good info in it. Where do you order the books from? Again has anybody used the install kit from CCP. It looks like quite a deal. I'm thinking about contacting them.
ranger57
You can order the books from Amazon or other booksellers like Barnes and Noble. The ISBN numbers I posted will help you find them or verify that an ad is the one I mentioned. I bought mine at a bookstore.
1 - 13 of 13 Posts
