My son is plumbing his 98 single fuel line LS1 in his 240Z. Dose this setup need a return line? He is using a F body pump in-tank pump.
I assume he is using fuel injection and an ECU too. If so - yes. You have to equalize the tank pressure and the in-tank pump does not do this.
There is only 1 line to the fuel rails, so this is a common question.
Basic system setup:
Fuel pump - filter - Tee - return back to tank - to regulator - return fuel into tank bottom, where the T has a single line to the fuel rails.
The stock tank and fuel pump should handle up to 600HP.
Hope that helps.
Post some photos, sounds like a fun project.
F-body has the return in the tank. Vettes have them externally, off the fuel filter/reg.
Chuck,
You are correct with the regulator location between a F-body tank and std. FI tank that requires an external regulator.
Even though the regulator is in the tank with the F-body, the one's I've installed needed a Tee junction for the return. It is not routed in the tank. I just set-up a friends 99 Camero with the F-body tank. The return actually goes to the bucket that the pump is inside, so maybe my routing was not clear. I tap-off the return after the filter (I've also done it before the filter) then back to the tank. Do you have a different experience with these tanks?
Thanks,
Nope. We use the Vette filter, and on the real hipo engines, use the Aeromotive reg, return line, and the Supra intank pump. I'm done w/ Walbros...
Beware, if you plumb the fuel lines up without a return line, you must use a stock LS1 pump with built in regulator in the tank. Otherwise you will not have pressure regulation at all. You will build pressure until the pump stalls (and probably blows a fuse or burns up the wire harness).
If you use a typical aftermarket pump, you need the Corvette filter/regulator (easiest way), or some other regulator setup (like one on the fuel rail), and those do require a return line. In the case of the Corvette filter/regulator, since it mounts near the tank, you don't have to run the return line the full length of the car.
I know some of you already know this, but it might clear things up for others.
He's using an LS1 in tank pump with a Vette regulator mounted in the rear by the tank with a short return line.
Sound like he's om track?
