1 - 2 of 2 Posts
I guess I should have know better but I didn't. I recently changed my 411 ECM and encountered the error code mentioned. Since I was had encountered problems with my original ECM, I had to change it out. I didn't know this would complicate things so. When the engine was in the open loop, it ran OK but once it went into closed loop, things got much different. The engine had no power, would misfire and want to die at idle when it was in gear. At first I thought it might be a MAF problem but when I disconnected it without a difference, that wasn't it. I haven't seen this problem discussed much and I thought I had a somewhat basic knowledge of the workings of the LS1/ECM relationship.
Once the car was taken to a dealer and the crankshaft relearn procedure was redone ($85), the car runs normally. The dealer said this was the problem and was somewhat common with ECM changes on these type engines. I was wondering if anyone had encountered this problem when an ECM was used that didn't come with the engine?
LS Tech and Moderator
Its typical and can happen i would say not uncommon thought from what i have seen. Mostly will effect wot the most. $85 is really good most dealers its 100 bill or more.
Ecm or motor change to an orginal ecm can cause it. Biggest thing is to have the park single hooked up slif tou have an auto so if you ever have to do it your not chasing wires or pins. Makes it easier later as the pcm will need these signles to do the relearn.
1 - 2 of 2 Posts
